program to save tables of various sizes to csv in a loop
mark
Postby mark » Mon Aug 24, 2015 11:45 am
I'm using a loop to generate then save tables that vary in size to csv files.
Each table varies in dimension - the number of rows and columns differ table to table about 30 or so in total.
I'm usng EV9 - enterprise edition and here is this is the code I use to export the cvs file:
p{%2}.save(r=B8:S15, t=csv, n="NAN") outp{%2}
Is there a trick to programing - ie can "r=B8:S15" definition be altered to a wildcard statement - so the program will read each table in each loop iteration, determine table dimensions then save the table tin csv format?
thanks
Re: program to save tables of various sizes to csv in a loop
Postby EViews Gareth » Mon Aug 24, 2015 11:48 am
I'm not sure I follow. Why do you need to use the r= option at all? You only want to save part of each table? If so, how do you know which part of each table you want to save?
mark
Postby mark » Mon Aug 24, 2015 2:17 pm
THANKS FOR POINTING THE "R=" OUT - REMOVED IT AND THINGS RUN SMOOTH - DUH...
