Auto regressive (AR) model uses previous points residual as regressor. Logically a model with AR(1) term should not have any prediction for first point as AR(1) value will be unavailable for the first point. Similarly a model with AR(2) term would not have any prediction for first 2 points and so on. For some reason that is not the case with EViews 9.
Does anybody know how the predicted values are calculated for Auto regressive (AR) model in EViews 9? Attached are an example EViews 9 work file and corresponding excel calculation.
[Urgent] AR models in EViews9 uses all data points
prit.ranjan
- Workfile.WF1
- Workfile
- (14.3 KiB) Downloaded 180 times
- AR1 example.xls
- Excel calculation
- (32.5 KiB) Downloaded 240 times
Re: [Urgent] AR models in EViews9 uses all data points
EViews 9 defaults to using ML to estimate AR models. Like GLS, ML estimation uses all data points.
Dropping the first data points is done when you estimate with conditional least squares. On your options tab of your equation is a combo for choosing the ARMA estimation method. Select CLS.
