[Urgent] AR models in EViews9 uses all data points
prit.ranjan
Postby prit.ranjan » Thu Aug 20, 2015 10:49 pm
Auto regressive (AR) model uses previous points residual as regressor. Logically a model with AR(1) term should not have any prediction for first point as AR(1) value will be unavailable for the first point. Similarly a model with AR(2) term would not have any prediction for first 2 points and so on. For some reason that is not the case with EViews 9.
Does anybody know how the predicted values are calculated for Auto regressive (AR) model in EViews 9? Attached are an example EViews 9 work file and corresponding excel calculation.
Workfile.WF1
Workfile
(14.3 KiB) Downloaded 181 times
AR1 example.xls
Excel calculation
(32.5 KiB) Downloaded 241 times
Re: [Urgent] AR models in EViews9 uses all data points
Postby EViews Glenn » Mon Aug 24, 2015 9:52 am
EViews 9 defaults to using ML to estimate AR models. Like GLS, ML estimation uses all data points.
Dropping the first data points is done when you estimate with conditional least squares. On your options tab of your equation is a combo for choosing the ARMA estimation method. Select CLS.
