@keep vs @drop
ian.e.preston
@keep vs @drop
Postby ian.e.preston » Fri Jul 03, 2015 1:21 pm
I'm trying to export a series to an excel file.
pagesave(t="excelxml") %file_out @keep x
creates an excel file with a date column and a series with a header that says "X" and then a whole series that is just X over and over
if I do pagesave(t="excelxml") %file_out @drop x2
it works as I'd expect, outputting all series except x2 with their numerical values. It really seems to be an issue with @keep.
I can workaround this issue by just dropping every other series, but given that I only want to export one series that's cumbersome. Any ideas what's causing this?
I'm using eviews 9
Re: @keep vs @drop
Postby EViews Gareth » Fri Jul 03, 2015 2:14 pm
Could you provide the workfile?
ian.e.preston
Re: @keep vs @drop
Postby ian.e.preston » Fri Jul 03, 2015 2:16 pm
Sure. I've also attached the program I'm using
Right now it's using drop, which as you can see is cumbersome.
lmi.prg
(3.49 KiB) Downloaded 273 times
lmi.wf1
(117.62 KiB) Downloaded 194 times
Re: @keep vs @drop
Postby EViews Gareth » Fri Jul 03, 2015 2:45 pm
which series are you trying to @keep?
ian.e.preston
Re: @keep vs @drop
Postby ian.e.preston » Mon Jul 06, 2015 6:33 am
lmi_t, but the issue is the same with whatever series I try.
Re: @keep vs @drop
Postby EViews Gareth » Mon Jul 06, 2015 8:26 am
What's the build date of your copy of EViews 9? (Help->About EViews).
ian.e.preston
Re: @keep vs @drop
Postby ian.e.preston » Mon Jul 06, 2015 8:30 am
April 20 2015.
Re: @keep vs @drop
Postby EViews Gareth » Mon Jul 06, 2015 8:47 am
Very out of date. Please update to the latest version.
