I'm trying to export a series to an excel file.
pagesave(t="excelxml") %file_out @keep x
creates an excel file with a date column and a series with a header that says "X" and then a whole series that is just X over and over
if I do pagesave(t="excelxml") %file_out @drop x2
it works as I'd expect, outputting all series except x2 with their numerical values. It really seems to be an issue with @keep.
I can workaround this issue by just dropping every other series, but given that I only want to export one series that's cumbersome. Any ideas what's causing this?
I'm using eviews 9
@keep vs @drop
Re: @keep vs @drop
ian.e.preston
Re: @keep vs @drop
Sure. I've also attached the program I'm using
Right now it's using drop, which as you can see is cumbersome.
Re: @keep vs @drop
which series are you trying to @keep?
ian.e.preston
Re: @keep vs @drop
lmi_t, but the issue is the same with whatever series I try.
Re: @keep vs @drop
What's the build date of your copy of EViews 9? (Help->About EViews).
Re: @keep vs @drop
Very out of date. Please update to the latest version.
