EViews 9 copy bug? - (c=c) i.e. cubic spline interpolation
hgrah
Postby hgrah » Wed Apr 29, 2015 12:00 am
I was pleased to hear that with EViews 9 support was said to be added for interpolation that allowed matches to "first" to complement the existing "last" option for cubic spline
However, I cannot see the option available in the copy command documentation, and when I use "last" now it seems to produce an interpolation based upon "first". If I use EViews 8 I get the correct lineup.
e.g.
copy(c=c) QCPI\iaupcz real\iaupcz
as per attachments.
It would be great if both options could be made to work for cubic spline
Graham
Re: EViews 9 copy bug? - (c=c) i.e. cubic spline interpolati
Postby EViews Steve » Wed Apr 29, 2015 7:45 am
This was actually fixed in the April 27 patch (released 2 days ago). Please update to that version and let me know if it works for you...
rousing
Re: EViews 9 copy bug? - (c=c) i.e. cubic spline interpolation
Postby rousing » Thu Sep 08, 2016 7:19 am
has this really been fixed? and what are the correct commands since i don't find this in the documentation c=cl, c=cf?
Best regards
Rasmus
Sep 2 2016 build
Postby EViews Steve » Thu Sep 08, 2016 7:29 am
Not sure how we missed this in our documentation, but here's the info you asked for:
For cubic spline match first, use the following:
c=cubicf
For cubic spline match last, you can use either
c=cubicl
or
c=c
I'll notify our documentation team about the missing info.
rousing
Postby rousing » Thu Sep 08, 2016 7:40 am
great thanks a lot :)
Postby EViews Steve » Thu Sep 08, 2016 7:43 am
Oh, one other note.
If you see that our documentation is missing something, with EViews 9 you can simply refer to the captured command after going thru the associated dialog. In this example, if you performed a manual copy operation and chose Cubic Match First for the up conversion, you'd see the c=cubicf option in the captured command.
I'll make sure our documentation is updated. Thanks for the heads up.
rousing
Postby rousing » Thu Sep 08, 2016 8:01 am
that was also a problem (otherwise i would not have written in the forum), when I converted the db linked series manually (to cubic first) - this did not reveal the code in the capture window...
Postby EViews Steve » Thu Sep 08, 2016 8:03 am
Were you performing a fetch when you did the conversion, or were you converting a series object already in your workfile to another page with a higher frequency?
rousing
Postby rousing » Thu Sep 08, 2016 8:17 am
i did a linked fetch with no other inputs ("fetch(d="db",link) seriresname") and then manually the frequency conversion afterwards
Postby EViews Steve » Thu Sep 08, 2016 8:47 am
Sorry, but I need a few more details.
When you performed the fetch, did you do it to a workfile with a matching frequency or did you do it to a higher frequency workfile?
Then how did you manually do the frequency conversion afterwards? Was there another workfile page with the target frequency involved or did you try to change the frequency conversion type in the fetch link?
Postby EViews Steve » Thu Sep 08, 2016 9:41 am
Well I looked into the FETCH captured command and it wasn't generating the correct conversion option.
I've changed this so the next patch should fix it. This means if you manually COPY an object in the database window, then do a PASTE special into a workfile window, then in the dialog select a specific conversion option, the resulting FETCH command should now reflect the proper c= option.
If you manually change a linked series' conversion option after doing the FETCH, we currently don't have a programmatic way of doing this (at least not directly) so there's no command to capture.
Thanks again.
rousing
Postby rousing » Fri Sep 09, 2016 5:50 am
great, thanks a lot for your help :)
