Graph Alpha series and number series
Panospaleos
I know it sounds easy but I have a problem. I have an alpha series and and another series with numbers.I want to make a graph with the two of them. The X axes with the alpha series and the Y axis with the number series. How can I do this?When I tried I get an empty graph.If you check the attached file you can see the series. I want to plot "back" series, which is alpha series, with lamda series. Can you help me?
- back.wf1
- (12.74 KiB) Downloaded 245 times
Re: Graph Alpha series and number series
What type of graph?
Panospaleos
A simple line graph. I just want to plot these variables. Nothing special...
Open up the lambda series, click on View->Graph, then go to Axis & Scaling -> Obs/Date axis, and then type in "back" in the "optional alpha or series to be used as observations labels" box.
Panospaleos
Thank you very much...
