Graph Alpha series and number series
Panospaleos
Postby Panospaleos » Sun Dec 21, 2014 7:13 pm
I know it sounds easy but I have a problem. I have an alpha series and and another series with numbers.I want to make a graph with the two of them. The X axes with the alpha series and the Y axis with the number series. How can I do this?When I tried I get an empty graph.If you check the attached file you can see the series. I want to plot "back" series, which is alpha series, with lamda series. Can you help me?
back.wf1
(12.74 KiB) Downloaded 246 times
Re: Graph Alpha series and number series
Postby EViews Gareth » Sun Dec 21, 2014 10:12 pm
What type of graph?
Panospaleos
Postby Panospaleos » Mon Dec 22, 2014 3:32 am
A simple line graph. I just want to plot these variables. Nothing special...
Postby EViews Gareth » Mon Dec 22, 2014 9:23 am
Open up the lambda series, click on View->Graph, then go to Axis & Scaling -> Obs/Date axis, and then type in "back" in the "optional alpha or series to be used as observations labels" box.
Panospaleos
Postby Panospaleos » Mon Dec 22, 2014 11:49 am
Thank you very much...
