1. I have daily data of 100 stocks, for 21 days (1 month), and i want to calculate the standard deviation of the group. How can this be done easily (without creating covariation matrices?).
Seems pretty easy to me, but I cannot work it out.
2. I want to calculate amultiple regression. I have two explanatory variables, that have to explain the return of every individual stock. So for every stock (of these 100) I want to do a multiple regression:
r (return of stock) = alpha + beta1 + beta2 + e
Is there a way to do this easily or must every regression for every stock be done individually?
Thanks (i'm using eviews 7)
standard deviation of group
Re: standard deviation of group
1) Convert the group into a matrix, and then calculate the statistics of interest
2) Loop through the members of the group (i.e. series), which can be done easily in EViews.
stom(mygr,mymat)
scalar sdev = @stdev(mymat)Re: standard deviation of group
Thanks. Im sorry, but i am really not good with Eviews.
1. Can @stdev(mymat) be done for more groups at one time?
How do I 'loop' ?2) Loop through the members of the group (i.e. series), which can be done easily in EViews.
1) Groups and Matrices are two different "object"s in EViews. Since you seem to wish to compute the pooled variance, I suggested the use of Matrix instead of Group. Again, if you need to compute a single (pooled) variance of all groups, then you need to create a larger matrix. Otherwise, you have to do it separately for each group.
2) http://forums.eviews.com/viewtopic.php?f=5&t=1638
