standard deviation of group
d0hMole
Postby d0hMole » Thu Oct 30, 2014 4:26 am
1. I have daily data of 100 stocks, for 21 days (1 month), and i want to calculate the standard deviation of the group. How can this be done easily (without creating covariation matrices?).
Seems pretty easy to me, but I cannot work it out.
2. I want to calculate amultiple regression. I have two explanatory variables, that have to explain the return of every individual stock. So for every stock (of these 100) I want to do a multiple regression:
r (return of stock) = alpha + beta1 + beta2 + e
Is there a way to do this easily or must every regression for every stock be done individually?
Thanks (i'm using eviews 7)
trubador
Did you use forum search?
Re: standard deviation of group
Postby trubador » Thu Oct 30, 2014 5:07 am
1) Convert the group into a matrix, and then calculate the statistics of interest
stom(mygr,mymat) scalar sdev = @stdev(mymat)
2) Loop through the members of the group (i.e. series), which can be done easily in EViews.
d0hMole
Postby d0hMole » Thu Oct 30, 2014 6:43 am
Thanks. Im sorry, but i am really not good with Eviews.
1. Can @stdev(mymat) be done for more groups at one time?
How do I 'loop' ?
trubador
Postby trubador » Thu Oct 30, 2014 7:37 am
1) Groups and Matrices are two different "object"s in EViews. Since you seem to wish to compute the pooled variance, I suggested the use of Matrix instead of Group. Again, if you need to compute a single (pooled) variance of all groups, then you need to create a larger matrix. Otherwise, you have to do it separately for each group.
2) http://forums.eviews.com/viewtopic.php?f=5&t=1638
