Eviews stops working when sorting series in graph
Postby tvonbrasch » Mon Oct 20, 2014 4:45 am
If you open the graph object gr_pw4 in the attached workfile, and press object, view options and sort, Eviews stops working.
I have Eviews 8.1, build oct 14.
What is causing this?
sortgraph.wf1
(1.49 MiB) Downloaded 311 times
Re: Eviews stops working when sorting series in graph
Postby EViews Jason » Mon Oct 20, 2014 10:29 am
It will be fixed in the next patch. EViews will error in future versions.
Were you just reporting the crash or did you also really want to sort? If you did want to sort, what were you expecting the output to look like?
Postby tvonbrasch » Mon Oct 20, 2014 11:03 pm
Hi Jason
Yes I would like to have the graph sorted. Is there an easy way of doing this?
Postby EViews Jason » Wed Oct 22, 2014 9:23 am
Correct me if I am wrong, but in that particular graph you are graphing a single value (such as the means per country).
Sorting in graphs normally means to sort the data in ascending or descending order. Since you are only graphing a single value, what would you like sorting to do?
Postby tvonbrasch » Thu Oct 23, 2014 2:47 am
you are correct. now, when i merge the graphs, i merge them according to their value:
Postby EViews Jason » Thu Oct 23, 2014 2:21 pm
The order of the series in the graph depends upon the order in which they are placed in to the group from which the graph was made. This cannot be changed. We'll investigate ways we could make sorting the series order of a group easier
