What information can I reference from a command?
bobreednz
Postby bobreednz » Tue Jul 22, 2014 4:54 pm
Hi, I know if I run a command, like ls, I can extract certain information for later use. For example, in the command below, I extract the tstat from the trend term.
ls y c @trend
scalar bob = @tstat(2)
My question is: Is there any way of knowing after ANY command, what all information is available for extraction, and how it can be referenced?
Re: What information can I reference from a command?
Postby EViews Gareth » Tue Jul 22, 2014 7:51 pm
What you're actually talking about are object data members. When you use the LS command you create an equation object. Then you can reference any of the equation's data members.
A list of each object's data members are given at the start of that objects section in Chapter 1 of the Object Reference (PDF available from the help menu).
bobreednz
Postby bobreednz » Tue Jul 22, 2014 8:18 pm
I am very sorry, but I went to the Object Reference pdf and did not see any mention of the object members nor how I could reference them. I am uploading the screen shot from the first page on "ls" in the Object Reference pdf. I don't see any mention of, for example, "@tstat()" which would let me know what members were available and how to reference them. I'd greatly appreciate additional help. :-)
Object reference (ls).docx
Screen shot from Object Reference (ls) pdf.
(950.14 KiB) Downloaded 196 times
Postby EViews Gareth » Tue Jul 22, 2014 8:39 pm
Go to the start of the equation section. The object you created is an equation object.
bobreednz
Postby bobreednz » Tue Jul 22, 2014 8:57 pm
Got it. So as I understand it after reading about the object members, I don't think there's any way to extract specific test results from the uroot command (such as the sample t-statistic or prob value), which is associated with a series object. The only way to do this would be run it as a LS equation and get the information from that. Is that correct?
Postby EViews Gareth » Tue Jul 22, 2014 9:22 pm
bobreednz
Postby bobreednz » Tue Jul 22, 2014 9:54 pm
Thank you very much. This has been very helpful. :D
