Forecasting using Kalman Filter
jmagomez
Postby jmagomez » Sat Jun 21, 2014 1:37 pm
Dear Fellows,
I would ask for your help.
I am developing a VEC Model analyzing Gasoline C Demand. And I am advancing to analyze Subst parameter (ethanol prices divided by gasoline c prices) volatility using Kalman Filter. It's ok for me to analyze the past, but I am trying to FORECAST Gasoline C consumption until December, 2031 using State Space/Kalman Filter. Is it possible?
And our Gasoline in Brazil is called Gasoline C.
The model has the object name "vecm_gasolinareal_subst":
lgasolinac c lsubst lmassasalarialreal
And I developed the state space object called "SSKFGASOLINAREALSUBSTKF".
I attached the file. Please save this file at Eviews5 version. And you can change to another ways using different types of Kalman Filter specifications.
Thanks a lot and Best Regards, Jose.
database_eviewsforum.wf1
(189.43 KiB) Downloaded 284 times
jmagomez
Re: Forecasting using Kalman Filter
Postby jmagomez » Fri Jun 27, 2014 6:15 pm
Hi Glenn,
I worked at the file and simplified it. But I am facing a problem, when I try to forecast I do not receive values, it puts NA (Not Available). The object is the SSVARGASOLINAREAL. My final objective is to obtain LgasolinaC forecast using Kalman Filter. Do I have a problem with the model? What would it be?
The file is attached.
Best Regards, José.
database_eviewsforum2.wf1
(103.45 KiB) Downloaded 294 times
