Dear Fellows,
I would ask for your help.
I am developing a VEC Model analyzing Gasoline C Demand. And I am advancing to analyze Subst parameter (ethanol prices divided by gasoline c prices) volatility using Kalman Filter. It's ok for me to analyze the past, but I am trying to FORECAST Gasoline C consumption until December, 2031 using State Space/Kalman Filter. Is it possible?
And our Gasoline in Brazil is called Gasoline C.
The model has the object name "vecm_gasolinareal_subst":
lgasolinac c lsubst lmassasalarialreal
And I developed the state space object called "SSKFGASOLINAREALSUBSTKF".
I attached the file. Please save this file at Eviews5 version. And you can change to another ways using different types of Kalman Filter specifications.
Thanks a lot and Best Regards, Jose.
Forecasting using Kalman Filter
- database_eviewsforum.wf1
- (189.43 KiB) Downloaded 285 times
Re: Forecasting using Kalman Filter
Hi Glenn,
I worked at the file and simplified it. But I am facing a problem, when I try to forecast I do not receive values, it puts NA (Not Available). The object is the SSVARGASOLINAREAL. My final objective is to obtain LgasolinaC forecast using Kalman Filter. Do I have a problem with the model? What would it be?
The file is attached.
Best Regards, José.
Best Regards, José.
- database_eviewsforum2.wf1
- (103.45 KiB) Downloaded 294 times
