Hi.
I would like to know if there is necessary to perform seasonal adjustment on employment just by looking on the graphs mentioned below (raw data).
Thanks in advance.
Seasonal adjustment graph
- 1.JPG (37.78 KiB) Viewed 3783 times
- Capture.JPG (24.01 KiB) Viewed 3783 times
Re: Seasonal adjustment graph
If you can see repetitive peaks/ troughs in the chart then you could consider seasonally adjusting the series. However, x12 has formal seasonality tests (d8a, m7 and g0 spectrum) that could be used to ascertain whether there is seasonality or not. Hope this helps.
