How to enter data into a panel workfile.
Re: How to enter data into a panel workfile.
In the Excel file, which column corresponds to the cross sections?
None i guess, i'm not quite sure how to do that
If you don't know what your cross sections are, it is unlikely that EViews will either.
could you care to explain that to me so I can modify the excel file accordingly? This is the latest file i used. does this show cross sections?
- Book1.xlsx
- (398.01 KiB) Downloaded 1790 times
ok, let's take another step back. You've asked how to have EViews recognise your panel data. How is your data panel data? I don't mean in terms of EViews. I don't mean in terms of Excel. I mean what makes your data panel data?
I'm looking at FDI inflows from 16 source countries into 14 host countries from 1990-2012 - which makes it a panel? to be honest i havent worked with panel data so far, so i'm not quite sure.
thanks for your patience gareth
A standard panel (2-dimensional) has a time dimension and a single cross-section dimension. You need to figure out how to define those in your data.
So there's no way I am gonna run my 3-dimensional panel in eviews
EViews will allow 3-dimensional panel data, sure. You just have to give it two cross-section identifiers. But most statistical techniques require a 2d panel.
Gareth,
Could you let me know how to do that? I need to employ a gravity model, hence the 3-dimensional panel data
Bring the file into EViews, then click on Proc->Structure/Resize, change the structure to dated panel, and enter the time and cross-section identifiers.
That's when i get the illegal panel structure error: Year nested with whatever I put as cross-section id (1:4186)
What did you enter?
i've looked through this thread but i can't find a way to use any of the programs to import my data from excel and stack them in eviews.
i attach the excel file, there are 230 cross sections, and 10 variables across 9 years (but some sheets will have less years).
Is there a way i can import them in a loop and stack them using as variable names the xls sheets? and as ids the b1, b2, b3, ... cross ids?
thanks!
m
thanks!
m
- bankDataEviewsForum.xlsx
- (188.78 KiB) Downloaded 1946 times
%file = "c:\temp\bankdataeviewsforum.xlsx"
%sheetnames = @tablenames(%file)
for %s {%sheetnames}
import %file @rename * {%s}*
pagestack x_11180?
