How to enter data into a panel workfile.
Re: How to enter data into a panel workfile.
Postby EViews Gareth » Wed Feb 11, 2015 7:26 am
In the Excel file, which column corresponds to the cross sections?
agaro123
Postby agaro123 » Wed Feb 11, 2015 8:39 am
None i guess, i'm not quite sure how to do that
Postby EViews Gareth » Wed Feb 11, 2015 8:56 am
If you don't know what your cross sections are, it is unlikely that EViews will either.
agaro123
Postby agaro123 » Wed Feb 11, 2015 9:11 am
could you care to explain that to me so I can modify the excel file accordingly? This is the latest file i used. does this show cross sections?
Book1.xlsx
(398.01 KiB) Downloaded 1688 times
Postby EViews Gareth » Wed Feb 11, 2015 9:15 am
ok, let's take another step back. You've asked how to have EViews recognise your panel data. How is your data panel data? I don't mean in terms of EViews. I don't mean in terms of Excel. I mean what makes your data panel data?
agaro123
Postby agaro123 » Wed Feb 11, 2015 9:17 am
I'm looking at FDI inflows from 16 source countries into 14 host countries from 1990-2012 - which makes it a panel? to be honest i havent worked with panel data so far, so i'm not quite sure.
thanks for your patience gareth
Postby EViews Gareth » Wed Feb 11, 2015 9:24 am
A standard panel (2-dimensional) has a time dimension and a single cross-section dimension. You need to figure out how to define those in your data.
agaro123
Postby agaro123 » Wed Feb 11, 2015 9:38 am
So there's no way I am gonna run my 3-dimensional panel in eviews
Postby EViews Gareth » Wed Feb 11, 2015 9:41 am
EViews will allow 3-dimensional panel data, sure. You just have to give it two cross-section identifiers. But most statistical techniques require a 2d panel.
agaro123
Postby agaro123 » Wed Feb 11, 2015 11:53 am
Gareth,
Could you let me know how to do that? I need to employ a gravity model, hence the 3-dimensional panel data
Postby EViews Gareth » Wed Feb 11, 2015 12:13 pm
Bring the file into EViews, then click on Proc->Structure/Resize, change the structure to dated panel, and enter the time and cross-section identifiers.
agaro123
Postby agaro123 » Wed Feb 11, 2015 12:55 pm
That's when i get the illegal panel structure error: Year nested with whatever I put as cross-section id (1:4186)
Postby EViews Gareth » Wed Feb 11, 2015 2:41 pm
What did you enter?
mikela
Postby mikela » Wed Mar 11, 2015 4:07 am
i've looked through this thread but i can't find a way to use any of the programs to import my data from excel and stack them in eviews.
i attach the excel file, there are 230 cross sections, and 10 variables across 9 years (but some sheets will have less years).
Is there a way i can import them in a loop and stack them using as variable names the xls sheets? and as ids the b1, b2, b3, ... cross ids?
thanks!
m
bankDataEviewsForum.xlsx
(188.78 KiB) Downloaded 1829 times
Postby EViews Gareth » Wed Mar 11, 2015 8:46 am
%file = "c:\temp\bankdataeviewsforum.xlsx" %sheetnames = @tablenames(%file) for %s {%sheetnames} import %file @rename * {%s}* next pagestack x_11180?
