simultaneous editing of program files
Re: simultaneous editing of program files
Postby EViews Jason » Fri Aug 12, 2016 11:28 am
You could use
run <mygoogledrive>:\testsave
but this assumes the file is named testsave.prg. Unfortunately you cannot use
run <mygoogledrive>:\testsave.txt
I would look into getting google docs to open text files that do not have *.txt extensions (ie get google docs to open prg files by default).
Postby tvonbrasch » Fri Aug 12, 2016 9:56 pm
perfect, thanks again!
Postby tvonbrasch » Tue Sep 06, 2016 4:37 am
After the last update, it works perfect! Being able to work on program files in Google Docs is great!
gdoc and eviews.JPG (186.75 KiB) Viewed 12841 times
Postby tvonbrasch » Tue Jul 17, 2018 8:22 am
Hi Jason
in 2016 you stated that "2) We are still working on this one.".
any progress yet?
Postby tvonbrasch » Wed Jul 18, 2018 6:30 am
Figured out an alternative way to execute Google Docs as EViews programs. Given a Google Document, such as,
google docs.PNG (31.99 KiB) Viewed 11708 times
use the FILE ID and insert it in the following program
%fileid= "1-T-3yjhYNJbwk3-8z_zf1afdGVo63iYLBM7TNeZybXY" call googledocs(%fileid) 'executes the Google Doc as EViews program '------------------------------------------------------------------------------- subroutine googledocs(string %fileid) %filename = "googledocs_may_be_deleted.txt" 'will be saved in @runpath folder %dir=@runpath 'downloading google doc as txt file %code1="wget https://docs.google.com/document/d/" %code2="/export?format=txt -OutFile " %code=%code1+%fileid+%code2+%dir+%filename shell powershell -command {%code} 'downloading google doc file 'create txt file to execute program %t=@getnextname("_t") 'txt file text {%t} 'create text file {%t}.append(file) {%dir}\{%filename} {%t}.save {%dir}\googledocrunprogram.prg 'save text file as program exec {%dir}\googledocrunprogram 'execute new program file close {%t} endsub
This way of doing it is a bit faster (takes 2,5 seconds instead of about 7 seconds when using the cloud connector in EViews) and Eviews will not unexpectedly shut down (http://forums.eviews.com/viewtopic.php?f=9&t=19330)
google_docs_as_program_file_eviews_forum.prg
(929 Bytes) Downloaded 1036 times
