diagnostic checks
johnsmith
diagnostic checks
Postby johnsmith » Mon Aug 16, 2010 7:36 am
k
Re: diagnostic checks
Postby startz » Mon Aug 16, 2010 7:37 am
The Drubin-Watson suggests you have significant serial correlation.
johnsmith
Postby johnsmith » Mon Aug 16, 2010 7:45 am
thanks for your reply
Is there a way to sort this out?
Postby startz » Mon Aug 16, 2010 8:16 am
You probably have a variety of omitted slow-moving variables that would help explain the spread. The best thing to do would be to include such variables. The second best might be to make a statistical adjustment. Look at AR(1) in the EViews help.
johnsmith
Postby johnsmith » Mon Aug 16, 2010 8:23 am
k
Postby startz » Mon Aug 16, 2010 9:07 am
Probably.
The remaining issue is whether this has picked up a real lagged effect or just masked serial correlation. Unfortunately, in the latter case all the coefficients are screwed up. Normally, one would test this last model for serial correlation. Unfortunately, EViews doesn't seem to implement a test for panel data.
The other issue is to realize that this new model introduces a dynamic response that you have to take into account.
