Could you please tell me which option allows to do this through a programming command?
Thanks,
Javier
Stacked bar chart "excel" style
tchaithonov
Re: Stacked bar chart "excel" style
You may want to do:
graph graph1.bar(s) x1 x2 x3-
EViews Pamela
graphname.option stackposneg
(and -stackposneg to stack using the EViews method)
Thanks Pamela,
I believe that this is not in the manual (like the option 'connect' which was raised in a previous post). If this is the case, are there any other new features not yet documented?
Thanks,
Javier
Thanks,
Javier
EViews Pamela
You are correct. It will be added and should be in future updates of the manual. (I believe "connect" is in the current version 7 manual.)
We do our best to document everything, so I am not aware of anything else undocumented. If you come across something, please let us know.
The current documentation doesn't cover theWe do our best to document everything, so I am not aware of anything else undocumented. If you come across something, please let us know.
writeThesisRe: Stacked bar chart "excel" style
Is it possible that when a new patch is provided the help reference file is updated as well as the pdfs?
Thanks,
Javier
Thanks,
Javier
EViews Pamela
Both the help and pdf's are updated.
