Stacked bar chart "excel" style
javiersan
Postby javiersan » Thu Jun 17, 2010 11:06 am
Could you please tell me which option allows to do this through a programming command?
Thanks,
Javier
tchaithonov
Re: Stacked bar chart "excel" style
Postby tchaithonov » Thu Jun 17, 2010 11:55 am
You may want to do:
graph graph1.bar(s) x1 x2 x3
EViews Pamela
Postby EViews Pamela » Thu Jun 17, 2010 12:03 pm
graphname.option stackposneg
(and -stackposneg to stack using the EViews method)
javiersan
Postby javiersan » Thu Jun 17, 2010 4:14 pm
Thanks Pamela,
I believe that this is not in the manual (like the option 'connect' which was raised in a previous post). If this is the case, are there any other new features not yet documented?
Thanks,
Javier
EViews Pamela
Postby EViews Pamela » Thu Jun 17, 2010 4:28 pm
You are correct. It will be added and should be in future updates of the manual. (I believe "connect" is in the current version 7 manual.)
We do our best to document everything, so I am not aware of anything else undocumented. If you come across something, please let us know.
Postby startz » Thu Jun 17, 2010 4:44 pm
The current documentation doesn't cover the
writeThesis
command. I'm sure a section covering all the options would be of interest to many EViews users.
javiersan
Postby javiersan » Fri Jun 18, 2010 3:01 am
Is it possible that when a new patch is provided the help reference file is updated as well as the pdfs?
Thanks,
Javier
EViews Pamela
Postby EViews Pamela » Fri Jun 18, 2010 10:55 am
Both the help and pdf's are updated.
