BVAR (Bayesian VAR)
BVAR (Bayesian VAR)
Postby EViews Gareth » Thu Apr 08, 2010 3:58 pm
This thread is about the BVAR Add-in that performs a Bayesian VAR estimation.
Change Log
  • 2010/04/08 - Initial release
  • 2010/04/09 - Better error handling for cases where there are NAs in the data or sample breaks
  • 2010/04/12 - Removed Nu, and fixed bug introduced by previous fix for sample breaks.
A new version of this Add-in has been released (2010/11/11), and a new forum thread has been created:
http://forums.eviews.com/viewtopic.php?f=23&t=3295
Re: BVAR (Bayesian VAR)
Postby EViews Gareth » Fri Apr 09, 2010 4:09 pm
Posted update that handles NAs and sample breaks better. Internal NAs or sample breaks will issue an error. NAs at the ends will cause the sample to be shrunk.
donihue
Postby donihue » Mon Apr 12, 2010 9:59 am
Dear Gareth,
Just a note to thank you greatly for having included BVARs in your list of Add-ins. You have made a large number of central bank users very happy indeed!
If DSGEs were also to find their way onto your list, we would reach Nirvana ...
Regards
Donihue
Postby EViews Gareth » Mon Apr 12, 2010 10:55 am
I was actually inspired by one of your previous posts - I read it and thought "I wonder if there is an R package that does it?", there was, and adding an EViews front-end to an R package is relatively simple (with a bit of practice), so making the BVAR add-in only took an afternoon or so.
donihue
Postby donihue » Mon Apr 12, 2010 11:24 am
Dear Gareth,
Further to this, in a quick test, using all the default settings, I do not find any output in the IRF tables. I have used MSBVAR as a standalone in the past without such problems. Has the porting to EViews somehow cleared these entries?
Regards
Donihue
Postby EViews Gareth » Mon Apr 12, 2010 11:36 am
Looks like something went wrong during the calculation of the BVAR - notice the log-likelihood is NA.
If you post your workfile, I'll see if I can figure out what is going on.
Although if you have some familiarity with MSBVAR, you might like to take a look yourself - if you go to the add-in folder for the BVAR add-in (probably "my documents\eviews addins\bvar") and then open up the bvar.prg program, and edit the first line so that it says !debug=1, then go to the bottom of the program and comment out the XCLOSE command, and save, when you run the Add-in, you should see the R Log open and see any errors that R reports.
Which points out I need to change that program so that !debug=1 automatically disables the XCLOSE command
donihue
Postby donihue » Mon Apr 12, 2010 11:42 am
Gareth,
As you saw, R could not find a solution to the model. Odd, since the full model runs fine as a standard VAR and as a BVAR under RATS ...
I found that when using a restricted version of the model, dropping the price variables, the routine works.
So (happily) it does not seem to be a "porting" problem, but a model-specific one. I will follow-up in R using your suggestion.
Regards
Donihue
donihue
Postby donihue » Mon Apr 12, 2010 12:14 pm
Gareth,
Having now looked into the documentation for the szbvar routine in MSBVAR, I find that nu is supposed to equal m+1, where m is the number of ts objects. Yet I find that whenever I run the add-in routine, I obtain nu=3. Hence, whenever I use 4 or more ts objects, the result is
"> xget(name = _MPOST01) BVAR$marg.post
R (for 'BVAR$marg.post') returned an error: unexpected fatal error in back-end implementation. release the object!."
(Curiously, it works when m=3 and nu also =3; but not if m=4 or more)
Also, the routine automatically appends the instruction "IF SMPLSER=1 AND" in the sample box but AFTER the sample, so it is always necessary to edit the sample to remove this addition.
Regards
Donihue
donihue
Postby donihue » Mon Apr 12, 2010 12:20 pm
Gareth,
Yet further to this, perhaps it would be better not to allow "nu" to be set in the add-in box, given that it is suposed always to be equal to m+1.
The problems I reported earlier disappear when I follow this convention in the add-in box.
Regards
Donihue
Postby EViews Gareth » Mon Apr 12, 2010 12:44 pm
Nu was a last minute addition that I probably didn't test as well as I should. I'll remove it. I'll also investigate the sample issue.
Thanks for the suggestions - my experience at both R and BVars is fairly limited.
Postby EViews Gareth » Mon Apr 12, 2010 2:24 pm
New update posted addressing samples and Nu
donihue
Postby donihue » Mon Apr 12, 2010 4:15 pm
Thanks very much Gareth.
Just tested the new version. Unfortunately, a similar sample problem arose - see photo below.
I also noticed that MSBVAR will work with nu >= m+1 (but not <) so perhaps an option for nu could still be left in, but coded so that it has to meet the >= m+1 condition
Regards
Donihue
Postby EViews Gareth » Mon Apr 12, 2010 5:37 pm
I'll contemplate Nu tomorrow.
I fixed a bug with the samples, but I'm not sure I follow your bug. That box simply gets filled out with the workfile sample when you run the add-in.
It might be that after a debugging run, or a run where R failed, the workfile sample is left in a bad state so that when you re-run the add-in, that box gets filled with junk.
donihue
Postby donihue » Tue Apr 13, 2010 2:02 am
Gareth,
Regarding the sample box, I think you are right - the problem seems to arise only when something goes wrong in R.
Another small point: the add-in box does not seem to retain the names of the endogenous variables from one estimation to the next (unlike, for example, the VAR dialogue); it would be nice if it did ...
Finally, szbvar allows for exogenous variables (in the matrix z). The default is z=NULL, but it does not have to be. Perhaps in a future revision, the add-in could also permit the use of exogenous variables?
Regards
Donihue
Postby EViews Gareth » Tue Apr 13, 2010 7:21 am
Remembering the variables is a little tricky to do in an add-in.
The version of msbvar I was working with does not yet support exogenous variables (although the docs say they will in the future)
Return to “Add-in Support”
