Multiple Dependent Variables
pbrownster
I have 1 discrete (dummy) explanatory variable which is time-series
pbrownster
Re: Multiple Dependent Variables
o
random_access
hi there
what r the dependent variables. as u explained ur independent is a dummy....i have not come a cross a model with indepedent being only dummy.....could u elaborate more and if possible write ur model
thanx
thanx
pbrownster
A logit regression was suggested
I am now a little confused with the best way to do this.
Thanks Again
Thanks Again
random_access
let me understand this ur dependent variable is Dummy....if so u can use logit model and run the series then....or u can use discriminant analysis in the SPSS. i'm not expert in logit model but it seems that this should be the way....
all the best
all the best
pbrownster
Thanks again for your continued help
random_access
there is a suggestion to do an ANOVA analysis. since u r test whehther the bailout will affect the performance of the banks.
if u want to do a regression analysis......u can run each performance measurement on the dummy.
how many dummy variables do u have?
pbrownster
Thanks again.
I have just the one dummy variable
pbrownster
1
random_access
that is good
may i know how did u run Granger causality on panel data?
if u have answered ur research questions then u should not go further
if u can send me the way u did the Granger causality i would be grateful
thanx
thanx
pbrownster
The granger method i just opened my data as a balanced panel (quarterly data) then highlighted the series i required and clicked: QUICK: GROUP STATISTICS: GRANGER CAUSALITY TEST: OK ....hope this helps
