Multiple Dependent Variables
pbrownster
Postby pbrownster » Thu Apr 01, 2010 9:18 am
I have 1 discrete (dummy) explanatory variable which is time-series
pbrownster
Re: Multiple Dependent Variables
Postby pbrownster » Thu Apr 01, 2010 11:48 am
o
random_access
Postby random_access » Fri Apr 02, 2010 1:23 am
hi there
what r the dependent variables. as u explained ur independent is a dummy....i have not come a cross a model with indepedent being only dummy.....could u elaborate more and if possible write ur model
thanx
pbrownster
Postby pbrownster » Fri Apr 02, 2010 4:49 am
A logit regression was suggested
I am now a little confused with the best way to do this.
Thanks Again
random_access
Postby random_access » Fri Apr 02, 2010 5:12 am
let me understand this ur dependent variable is Dummy....if so u can use logit model and run the series then....or u can use discriminant analysis in the SPSS. i'm not expert in logit model but it seems that this should be the way....
all the best
pbrownster
Postby pbrownster » Fri Apr 02, 2010 5:25 am
Thanks again for your continued help
random_access
Postby random_access » Fri Apr 02, 2010 10:03 pm
there is a suggestion to do an ANOVA analysis. since u r test whehther the bailout will affect the performance of the banks.
if u want to do a regression analysis......u can run each performance measurement on the dummy.
how many dummy variables do u have?
pbrownster
Postby pbrownster » Sat Apr 03, 2010 5:57 am
Thanks again.
I have just the one dummy variable
pbrownster
Postby pbrownster » Sat Apr 03, 2010 8:45 am
1
random_access
Postby random_access » Mon Apr 05, 2010 1:02 am
that is good
may i know how did u run Granger causality on panel data?
if u have answered ur research questions then u should not go further
if u can send me the way u did the Granger causality i would be grateful
thanx
pbrownster
Postby pbrownster » Mon Apr 05, 2010 6:42 am
The granger method i just opened my data as a balanced panel (quarterly data) then highlighted the series i required and clicked: QUICK: GROUP STATISTICS: GRANGER CAUSALITY TEST: OK ....hope this helps
