python xput & xrun working differently in EViews 14?
amrsherif
Postby amrsherif » Thu Nov 28, 2024 8:20 am
I have been using an addin for the past several years. It passes an EViews string to python as a list, which then gets processed and data is returned back to EViews.
I am noticing that it does not work in EViews14.
my code is simple:
xput(name=series, ptype=list) input
xrun "data = fetch_2(series)"
I am getting a "NameError: name 'series' is not defined"
I get the same error if i try: xrun "print('series')"
Any ideas would be greatly appreciated.
Re: python xput & xrun working differently in EViews 14?
Postby EViews Steve » Thu Nov 28, 2024 12:20 pm
It looks like XPUT's name option is being ignored. Running your XPUT command is creating an object named 'input' instead of 'series'. This does not happen in EViews 13.
We'll get this fixed.
amrsherif
Postby amrsherif » Thu Nov 28, 2024 1:25 pm
Ok thanks. Will wait for the fix
Postby EViews Steve » Mon Dec 02, 2024 2:40 pm
Fix has been released in today's 14 patch.
amrsherif
Postby amrsherif » Wed Dec 04, 2024 9:13 am
Thanks, but there is still an issue (my script still works in older versions but not 14).
Right now, i am calling back to python objects:
xget(type=series) datalist
xget(type=alpha) dateslist
printing the objects in python works: xrun "print(datalist[0:10])"
However, I cannot use them in EVIews after calling them.
I get an error: "datalist is not defined"
Postby EViews Steve » Mon Dec 09, 2024 10:21 am
Thanks for the info. XGET also had an issue (a different one) with the name option. Fix will be put into the next 14 patch.
amrsherif
Postby amrsherif » Thu Dec 19, 2024 8:18 am
Thanks. Any idea when the patch will be released?
Postby EViews Steve » Thu Dec 19, 2024 2:03 pm
Just released a new patch.
