I have been using an addin for the past several years. It passes an EViews string to python as a list, which then gets processed and data is returned back to EViews.
I am noticing that it does not work in EViews14.
my code is simple:
xput(name=series, ptype=list) input
xrun "data = fetch_2(series)"
I am getting a "NameError: name 'series' is not defined"
I get the same error if i try: xrun "print('series')"
Any ideas would be greatly appreciated.
python xput & xrun working differently in EViews 14?
Re: python xput & xrun working differently in EViews 14?
It looks like XPUT's name option is being ignored. Running your XPUT command is creating an object named 'input' instead of 'series'. This does not happen in EViews 13.
We'll get this fixed.
Ok thanks. Will wait for the fix
Fix has been released in today's 14 patch.
Thanks, but there is still an issue (my script still works in older versions but not 14).
Right now, i am calling back to python objects:
xget(type=series) datalist
xget(type=alpha) dateslist
printing the objects in python works: xrun "print(datalist[0:10])"
However, I cannot use them in EVIews after calling them.
I get an error: "datalist is not defined"
Thanks for the info. XGET also had an issue (a different one) with the name option. Fix will be put into the next 14 patch.
Thanks. Any idea when the patch will be released?
Just released a new patch.
