EViews stops working ...
Postby tvonbrasch » Mon Sep 30, 2024 6:59 am
when you install the attached prg-file as an addin named LINEA, and then execute the commands:
linea x
line x
EViews shows strange behaviour and stops working.
linea .jpg (88.59 KiB) Viewed 44733 times
Panes and tabs mode is activated.
linea.prg
(10.53 KiB) Downloaded 21237 times
Re: EViews stops working ...
Postby EViews Gareth » Tue Oct 01, 2024 7:35 am
I can't replicate this. Is your copy of EV14 up to date?
Postby tvonbrasch » Tue Oct 01, 2024 8:10 am
yes:
Skjermbilde 2024-10-01 170251.jpg (43.2 KiB) Viewed 44676 times
these are the commands I use:
Skjermbilde 2024-10-01 170418.jpg (88.67 KiB) Viewed 44676 times
and with the last line command, there is an error with the graph object (view, proc buttons are on top of each other), and then the program stops.
attached is the program I used to install the add-in.
What specific information do you need from me to reproduce the error I'm experiencing on your end?
t
linea_install.prg
(179 Bytes) Downloaded 21225 times
Postby EViews Steve » Tue Oct 01, 2024 9:48 am
Hmm, strange problem.
I narrowed it down to a program calling SHOW(max) while pane & tab mode is on. I wasn't able to figure out the exact cause, but I've put in a workaround for now so that this doesn't happen. Basically, the max option will be ignored when a program asks for is while pane & tab mode is on.
Fix will be in the next 13 & 14 patches.
Postby tvonbrasch » Tue Oct 01, 2024 10:04 am
Great, thanks!
