EViews does not read some columns from a .csv.
youngil
Postby youngil » Sun Sep 22, 2024 12:26 am
I've got an issue with reading a .csv file.
The csv file contains daily data from 05/04/1964 to 09/20/2024 of 64 series. The first column is "Date" formatted as yyyymmdd. The problem is EViews does not read columns after "EXR".
I'm using EViews version 13 at home and version 14 at work. Both versions have the same problem.
Data in CSV file:
Data in EViews:
Currently, I have the following line, where %freq is one of "A" "Q" "M" "D":
import %tmp_file ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=comma colhead=1 namepos=all eoltype=pad badfield=NA @freq {%freq} @id @date(date) @smpl @all
The line works well with frequencies "A" "Q" "M", except "D". My guess is it is because of many blanks at the beginning of the daily data after "EXR".
I have tried the followings as well:
wfopen(scan=all) %tmp_file
The same result as shown above.
read(name, label=1) %tmp_file 1000
This reads all columns but fails to treat the first "Date" column as dates.
Any suggestion?
Re: EViews does not read some columns from a .csv.
Postby EViews Steve » Sun Sep 22, 2024 11:44 am
Please provide the CSV file, or maybe just the first 10 lines, so we can try to replicate the issue.
youngil
Postby youngil » Sun Sep 22, 2024 1:59 pm
Hi, Steve
Here's a truncated version of the data file.
Thanks for the prompt response.
Data_truncated.csv
(787.87 KiB) Downloaded 22808 times
Postby EViews Steve » Sun Sep 22, 2024 3:36 pm
Ok, I think the fact that your CSV file has a lot of values that are missing (NA) is causing the issue. Our import wizard tries to figure out how much data to import based on looking ahead and counting how many values exist for the first certain number of rows (I don't remember the exact row count) and judging from your data, it looks like the rows mostly only had data up to the EXR column, which is why the import wizard stopped there.
I noticed that the last few lines of data in the text file had more data values, so I reversed the order of the rows (after the header) and imported that. This resulted in a lot more columns being imported, but it still dropped a lot from the end since they didn't have any data.
I did find these two IMPORT elements (available during a text file import, see here) which, I believe, fixed the issue:
scan=all
and
lastcol
So your import command should look something like this:
import "Data_truncated.csv" ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=comma colhead=1 scan=all lastcol namepos=all eoltype=pad badfield=NA @freq D7 @id @date(date) @smpl @all
youngil
Postby youngil » Sun Sep 22, 2024 6:11 pm
Hi Steve,
"scan=all lastcol" is the solution and fixes the problem.
Thanks a lot for your prompt and exact response!
Best,
youngil
