addinit(v=a)
addinit(v=a)
Postby tvonbrasch » Fri Feb 02, 2024 7:57 am
If you first solve a model, then use addinit(v=a), and then solve the model again, why can the solver then terminate?
I thought that the residuals would be set to the values they had in the first simulation when using the addinit(v=a) command. What could cause the solver to terminate when the addinit-command is used in this way?
random_user
Re: addinit(v=a)
Postby random_user » Mon Feb 05, 2024 9:33 am
It seems that this is specific to the model you're using. Because I tried it on my end, and the model I was using solved successfully both times. Strange!
Re: addinit(v=a)
Postby tvonbrasch » Sat Feb 10, 2024 8:54 am
Thanks for looking into this, random_user! I still don't understand the cause, but I think it is related to the actexist-option being activated.
EViews Matt
Re: addinit(v=a)
Postby EViews Matt » Mon Feb 12, 2024 6:17 pm
It's possible that if solution values (or expressions they appear in) are very close to numeric singularities, then the adjustment of add factors combined with the solution rounding and significant digits setting could produce such failures. Here's a small program that demonstrates this effect:
create u 10 series x = 3e-8 series x_a = 3e-8 model m m.append x = x(-1) m.append y = @log(3.3e-7 - x) m.addassign x m.solve m.addinit(v=a) @all m.scenario "Scenario 1" m.solve
Re: addinit(v=a)
Postby tvonbrasch » Sat Feb 17, 2024 3:20 am
Thanks, Matt, for looking into this!
Return to “Models”
