Normtest
EViews Esther
Normtest
This thread is about the Normtest add-in that includes many of the dozens of techniques for assessing univariate/multivariate normality.
lucem_fert
Re: Normtest
Hi!
I'Ve downloaded this Add-in but i don't understand how i can use it. Anyone knows it?
Thanks.
Thanks.
Normtest
I'm sure it has documentation, available from the manage add-ins menu.
lucem_fert
Re: Normtest
Yes you're right!!
It was very very late in the night when i was studyng it!
JamieLevon
Re: Normtest
I can't access the documentation. Where is the add-ins menu?
Re: Normtest
Between the Options menu and the Window Menu in EViews 7.2.
Re: Normtest
I would like to use the normtest in a program,
which are the comand references?
EViews Esther
Re: Normtest
There is no specific section for the command lines, however, each section has the following information:
Add-in Types: Object of interest
Default Proc Name: Command
For example, if you would like to run from the series, you can use the command:
as specified in section UniNorm.
series_name.uninormRe: Normtest
Thanks a lot!
How can i write a program that performs uninorm for many series and store for each series the results?
EViews Esther
Re: Normtest
Let me introduce one ad hoc approach. After editing the program, UNIFORM.prg (please see the attachment), you can run the following codes:
Please note this is an ad hoc approach.
group g ser1 ser2 ser3
for !i=1 to g.@count
%sername = g.@seriesname(!i)
series {%sername}
{%sername}.uninorm next
- fig.JPG (37.59 KiB) Viewed 106416 times
Re: Normtest
hello
I want to store the values "Statistic" and "Prob" of Shapiro-Wilk Test in tow variables (with run Normtest add ins). How should I do this programmatically? thank you
Re: Normtest
hello
How can i freeze x.uninorm ?
No matter how hard I try, it doesn't work.
Thank you
Thank you
Re: Normtest
Probably best off just modifying the source code of the add-in to store whatever you want stored. In effect creating your own version tailored to do what you want it to do.
Re: Normtest
Thank you very much for your help, problem solved
