It seems that in EViews 13 "Graph option - Rotated - obs axis on left" works improperly for "Line & Symbol" and "Area".
In EViews 12 this option works fine.
Improper work: Rotated - obs axis on left
Re: Improper work: Rotated - obs axis on left
Could you provide an example? I quickly tried with a random workfile I had opened, and it worked as expected.
Hi, Gareth,
Please try, for instance, file eupop.wf1 from EViews manual and rotate data represented as line or area.
Another good example in this season is your nice New Year Tree from: http://www.eviews.com/blog/xmas.prg. Try it in EViews 13 and you can see the problem. EViews 12 works properly.
Best,
Igor
Best,
Igor
Is your copy of EV13 up to date?
Dec 19 2023 build
- fig2_rotate.JPG (72.64 KiB) Viewed 90093 times
- fig1.JPG (75.77 KiB) Viewed 90093 times
We'll investigate.
