I have experienced an issue computing the Johansen cointegration test in EViews 13.
When using Model 2 (Cointegrating constant), I got the message “Could not compute valid eigenvectors/eigenvalues”.
I guess there is a bug code in EViews 13 because I can run the cointegration test (using Model 2) in previous versions of EViews without a problem. Furthermore, I can estimate a VECM using Model 2 in EViews 13, making me think about a bug code.
Additionally, I have experienced this problem with different datasets.
Can someone help me with this issue?
Thanks!
Compute eigenvectors/eigenvalues EViews 13
- Screenshot 2023-06-23 110728.png (21.42 KiB) Viewed 16260 times
- Screenshot 2023-06-23 110947.png (24.48 KiB) Viewed 16260 times
- qtm.wf1
- (21.68 KiB) Downloaded 903 times
Re: Compute eigenvectors/eigenvalues EViews 13
What's the build date of your copy of EViews 13? (Help->About EViews).
It says Jun 14 2023 build.
- Screenshot 2023-06-28 092909.png (32.47 KiB) Viewed 16162 times
Could you provide your workfile?
In the workfile qtm.wf1 you can find VARMONEY. If I try to run the Johansen cointegration test using Lags intervals 1 1 and Model 2 (Cointegrating constant), I get the message "Could not compute valid eigenvectors/eigenvalues".
Thanks for your help!
- qtm.wf1
- (21.68 KiB) Downloaded 910 times
I was wondering if you could take a look at the dataset to analyze the problem in computing Eigenvalues under Model 2 in EViews 13
The most recent patch should fix this issue.
It is now working!
