Hi all!
I was wondering if there is a way to tell EViews to shade a graph whenever the variable is decreasing.
Thank you in advance!
Shade by variable movement
Re: Shade by variable movement
When you add shading to a graph, you can specify a sample string, which could be an if condition such as:
if x<x(-1)
- 2023-03-23_092539.png (12.83 KiB) Viewed 55566 times
anacatelen
Thank you very much!When you add shading to a graph, you can specify a sample string, which could be an if condition such as:Code: Select all
if x<x(-1)
