Diebold-Yilmaz index
pschneider
Re: Diebold-Yilmaz index
Postby pschneider » Tue Dec 20, 2022 12:29 pm
thanks. does the fromvar1_matrix represent spillovers from series i to the whole matrix or all j?
dakila
Postby dakila » Tue Dec 20, 2022 1:58 pm
Each column in the fromvar (tovar) matric is the share of variance due to (contributing to) other units.
pschneider
Postby pschneider » Wed Dec 21, 2022 9:20 am
I'm frequently getting "error 6 in program", using eviews 12, and daily chg data on bond yields. It seems to be fine if I just use the level of yields. Any possible reason? Would having a few zeros create problems?
pschneider
Postby pschneider » Wed Dec 28, 2022 2:06 pm
Thanks. To clarify, some of my columns are >100 in tovar, so I'm trying to figure out how to interpret this (as it can't be the percent share). Do I need to take another step, so column 1/divided sum of columns, would be the outward spillover index for that variable?
To be very specific, does the 'tovar' metric correspond to the row "contribution to others" in the attached matrix (on a rolling basis of course)?
kzmh78
Postby kzmh78 » Fri Feb 17, 2023 1:39 am
Hello, when I calculate the Diebold-Yilmaz spillover index using 51 series, I get the error message 'Error 1114 in encrypted program'.
Is there an upper limit to the number of series available?
I am an EViews13 user and used the command line ('dyindex 4 @ ser01 ser02 ser03 ... ser51').
dakila
Postby dakila » Tue Feb 21, 2023 2:44 pm
No. Maybe you have matrix inversion problem because of multicollinearity.
kzmh78
Postby kzmh78 » Wed Feb 22, 2023 12:27 am
Thanks for your comment! I will check it out.
ecshukri
Postby ecshukri » Tue Jun 13, 2023 5:30 pm
Hello, when I tried to run the Add-in, the following error message came up "Error 20 in encrypted program". What's the problem here?
dakila
Postby dakila » Wed Jun 14, 2023 4:32 am
You have to open the data file with extension wf1 before open the dialog box (the menu).
ecshukri
Postby ecshukri » Thu Jun 15, 2023 7:48 pm
Thanks for the feedback. There is another error message = Error 500 in encrypted program. Any idea what this is? And if you could share a list of error messages for the dyindex is much appreciated. That would help me to troubleshoot.
dakila
Postby dakila » Fri Jun 16, 2023 1:50 am
Sorry, I don't have all error messages. You have to careful to input data and choose the parameter options.
shuhenchiang
Postby shuhenchiang » Thu Feb 26, 2026 9:29 pm
Dear all:
I am required to offer program codes of this dyindex in Eviews.
Please give me any help and I am highly appreciated for your support.
Sincerely
Mark
dakila
Postby dakila » Sun Mar 01, 2026 5:37 pm
Matlab code of the DY index is available for public. Goodluck!
Return to “Add-in Support”
