Seasonal Adjustment Error: "TRAMO/seats.itr not found"
Re: Seasonal Adjustment Error: "TRAMO/seats.itr not found"
Could you let us know which options you set via dialog that work?
uyanikcaner
I have uploaded 3 screenshots here related to the Tramo/Seats options that I set via dialog. The 3rd screenshot contains the code that I obtain from the Capture section. I have specific user holiday series (named t9) in order to adjust for calendar effects. Even if Tramo/Seats works when I use the dialog box, it shows the error message when I run the program file consisting of only the related code.
On the other hand, when I untick the box for the trading day effect and try to adjust the series via the program file, it works.
- TramoSeatsOptions3.png (144.24 KiB) Viewed 10933 times
- TramoSeatsOptions2.png (130.96 KiB) Viewed 10933 times
- TramoSeatsOptions1.png (131.61 KiB) Viewed 10933 times
Got it. This will be fixed in next patch.
uyanikcaner
Thank you for your quick response Gareth. I really appreciate it.
In addition, could you provide an estimated date for the next patch? We as a team have like 30+ plus monthly and quarterly series to be adjusted for calendar and seasonal effects, and as you can easily figure out, doing it manually is a heavy toll on us.
I once again thank you for your kind and warm support.
Sincerely,
Caner.
Sincerely,
Caner.
A couple of weeks.
Given that TRAMO/SEATS is 30 years old, we strongly recommend moving to X13 (which does every thing that tramo/seats does, theoretically).
