Graph Sample Range
GFXFTS
Graph Sample Range
Postby GFXFTS » Fri Mar 05, 2021 5:51 am
Hope all well.
Is there sample command which only uses the data available i.e. non-N/A for the series I would like to use for a graph by chance?
I have attached a workfile with some data. In the graphs, I would ideally only display the available data and start the sample, where both series are available.
Thanks a lot for your help.
Best,
Günter
fx_yield_spreads_d.wf1
(27.1 MiB) Downloaded 290 times
Re: Graph Sample Range
Postby EViews Gareth » Fri Mar 05, 2021 7:58 am
Put them in a group, then use:
smpl if @robs(g) = g.@count
GFXFTS
Postby GFXFTS » Fri Mar 05, 2021 9:36 am
Great. That worked. Thanks a lot. Best, Günter
