Hope all well.
Is there sample command which only uses the data available i.e. non-N/A for the series I would like to use for a graph by chance?
I have attached a workfile with some data. In the graphs, I would ideally only display the available data and start the sample, where both series are available.
Thanks a lot for your help.
Best,
Günter
Graph Sample Range
Graph Sample Range
- fx_yield_spreads_d.wf1
- (27.1 MiB) Downloaded 289 times
Re: Graph Sample Range
Put them in a group, then use:
smpl if @robs(g) = g.@count
Great. That worked. Thanks a lot. Best, Günter
