Error "Variable is not defined" in panel ARDL
nhunghatinh
Hi everyone. I am a new member. Nice to join this forum. Could you please help me with my problem
I am running panel ARDL for a panel data set. My model: lco2 lfdi lgdp lgdp2 ltrade lurbanization
All variables are I (1). When I run ARDL model for this panel data set, it says "lco2 is not defined", and when I changed lgdp to become dependent variables, it also says "lgdp is not defined". In general, It has the same notification when another variable is chosen as the dependent variable. I have been stuck for a few days and feel frustrated. :(. I am using eviews 11 student version (the trial version provided by eviews).
Please take a look and help me if you can. Thank you so much
Re: Error "Variable is not defined" in panel ARDL
Do you have a variable with that name in your workfile?
nhunghatinh
Hi EViews Gareth. Thanks so much for your reply. I do types the name of variables correctly. I think the problem occurs with any variables chosen as dependent variable.Do you have a variable with that name in your workfile?
There are two things you might do that would be helpful.
(1) Post the build date of your copy of EViews. (Help/About EViews)
(2) Post your workfile, including the VAR object you are trying to estimate.
nhunghatinh
THanks startzThere are two things you might do that would be helpful.
Hi. As the trial version does not allow me, I can not send the eviews file.I have posted the excel file here. Hope that everyone can help me. Really look forward to hearing from you
- panel 2. eviews.xlsx
- (17.79 KiB) Downloaded 745 times
nhunghatinh
Here is screenshotTHanks startzThere are two things you might do that would be helpful.
- Screen Shot 2021-01-04 at 08.36.50.png (44.11 KiB) Viewed 14606 times
- Screen Shot 2021-01-04 at 08.36.16.png (57.74 KiB) Viewed 14606 times
lco2 is not in the Excel spreadsheet you uploaded.
nhunghatinh
Thanks for replying. But I create the log variable in the eviews (as you can see in the post)lco2 is not in the Excel spreadsheet you uploaded.
I see that it is in the picture, but I don't know how you created the variable. I also don't know how you created the other variables that are not in the Excel workfile.
Also, while it is very unlikely that you've hit a bug it is not impossible. It would help the EViews team if you told them the build date of your version.
nhunghatinh
Thanks so much for replying startz. I transform variable into log form, the original is not in log form. That is why you dont see the log variable in the spreadsheet. I can not send you the workfile as i am using Eviews 11 student lite version (which has many limitations), which does not allow to save my file. Would you mind transforming my data to log form and run ARDL in your eviews to see if you have similar errors? I am using macbook, which causes me difficult to install eviews without buying it. I attached a picture of the eviews version . Hope to hear from you
- Screen Shot 2021-01-06 at 11.07.59(2).png (42.05 KiB) Viewed 14550 times
What is gdp2? It is not in the Excel file.
To follow on from Startz' question(s), it would be extremely helpful if you could outline exactly what you do to get from the Excel file you provided to the error message you see.
It is frustrating to people, who are only trying to help you, to have to keep asking you the same thing.
nhunghatinh
Thanks so much for your help startz. I will stop asking this question.What is gdp2? It is not in the Excel file.
nhunghatinh
Hi. Thanks for your feedback. You do not understand me because I can not save the work file and post here (this lite version do not allow me) so that it is easier for you to understand. I will stop asking this question. Thanks
nhunghatinh
Thanks so much for your help startz. Really appreciate your time and effort. I will stop asking this question.What is gdp2? It is not in the Excel file.
