CUSUM Test in ARDL Models
themba.chirwa
Colleagues,
I am using Eviews 9 and I have been searching if I can also use the CUSUM Test after estimation of an ARDL model. Does anyone have any suggestions on how this can be done.
Thanks in advance.
Best,
Themba Chirwa
Thanks in advance.
Best,
Themba Chirwa
Re: CUSUM Test in ARDL Models
Currently it isn't available, but will be via an update soon.
Appiah-Konadu
Collegues I want to estimate the ARDL cointegration model using Eviews 7 but I cannot find it in the drop down menu. can someone help me out with the procedureCurrently it isn't available, but will be via an update soon.
It was added in EViews 9.
Hi I am using CUSUM test for ARDL models in Eviews 11. However although I have 5 years of daily data from 2015 to 2019, my CUSUM test output graph only includes values calculated for 2019. How can I able to view CUSUM Stats for 5 years period. Thank you very much
More details needed:
create m 2015 2019
series y=nrnd
series x=nrnd
equation eq1.ardl y x
show eq1.rls(q) c(1) c(2) c(3)
For monthly data your code showed CUSUM graphics for all years. But I am working on daily data with 1826 obs. and can still only see 2019 values for CUSUM
create d7 2015 2019
series y=nrnd
series x=nrnd
Your simulated data prints CUSUM test results for entire time line. However it is not the case for my equation. I have 39 dynamic terms and about 80 fixed terms in my model. Does these fixed terms could be the reason behind this problem
Can you guess what is the possible problem behind this problem? I can check further specification errors in my work file
I'm guessing you're doing something wrong, but without further details, it is impossible to guess what.
As I said before I have 111 independent vars, which 39 of them enters the dynamic part of ARDL eq., in addition I have 80 fixed variables in the model. I have 1826 obs and I am using white het. resistant se estimation. My after estimating my model, I run view/stability tests - CUSUM test. This is te case... But I cant see the recursive calculation for entire sample, I can only see values for 2019
