CUSUM Test in ARDL Models
themba.chirwa
Postby themba.chirwa » Thu Jun 04, 2015 12:49 am
Colleagues,
I am using Eviews 9 and I have been searching if I can also use the CUSUM Test after estimation of an ARDL model. Does anyone have any suggestions on how this can be done.
Thanks in advance.
Best,
Themba Chirwa
Re: CUSUM Test in ARDL Models
Postby EViews Gareth » Thu Jun 04, 2015 8:09 am
Currently it isn't available, but will be via an update soon.
Appiah-Konadu
Postby Appiah-Konadu » Fri Jun 05, 2015 6:26 am
Collegues I want to estimate the ARDL cointegration model using Eviews 7 but I cannot find it in the drop down menu. can someone help me out with the procedure
Postby EViews Gareth » Fri Jun 05, 2015 6:38 am
It was added in EViews 9.
omerz
Postby omerz » Thu Apr 30, 2020 3:00 pm
Hi I am using CUSUM test for ARDL models in Eviews 11. However although I have 5 years of daily data from 2015 to 2019, my CUSUM test output graph only includes values calculated for 2019. How can I able to view CUSUM Stats for 5 years period. Thank you very much
Postby EViews Gareth » Thu Apr 30, 2020 3:05 pm
More details needed:
create m 2015 2019 series y=nrnd series x=nrnd equation eq1.ardl y x show eq1.rls(q) c(1) c(2) c(3)
omerz
Postby omerz » Thu Apr 30, 2020 3:12 pm
For monthly data your code showed CUSUM graphics for all years. But I am working on daily data with 1826 obs. and can still only see 2019 values for CUSUM
Postby EViews Gareth » Thu Apr 30, 2020 3:27 pm
create d7 2015 2019 series y=nrnd series x=nrnd equation eq1.ardl y x show eq1.rls(q) c(1) c(2) c(3)
omerz
Postby omerz » Thu Apr 30, 2020 3:39 pm
Your simulated data prints CUSUM test results for entire time line. However it is not the case for my equation. I have 39 dynamic terms and about 80 fixed terms in my model. Does these fixed terms could be the reason behind this problem
Postby EViews Gareth » Thu Apr 30, 2020 3:57 pm
No.
omerz
Postby omerz » Thu Apr 30, 2020 4:01 pm
Can you guess what is the possible problem behind this problem? I can check further specification errors in my work file
Postby EViews Gareth » Thu Apr 30, 2020 4:06 pm
I'm guessing you're doing something wrong, but without further details, it is impossible to guess what.
omerz
Postby omerz » Thu Apr 30, 2020 4:13 pm
As I said before I have 111 independent vars, which 39 of them enters the dynamic part of ARDL eq., in addition I have 80 fixed variables in the model. I have 1826 obs and I am using white het. resistant se estimation. My after estimating my model, I run view/stability tests - CUSUM test. This is te case... But I cant see the recursive calculation for entire sample, I can only see values for 2019
