Update leading to higher run times?
twash@slu.edu
Postby twash@slu.edu » Tue Mar 03, 2020 10:17 am
The update from eviews 10 to eviews 11, led to a drastic increase in the run time of my programs. A program that would run in five minutes can sometimes take hours. The slowdown appears to be due to it taking longer to generate equations. Does anyone else have this problem?
EViews Matt
Re: Update leading to higher run times?
Postby EViews Matt » Tue Mar 03, 2020 10:27 am
Would you be able to post one of the programs that is running slowly in EViews 11?
twash@slu.edu
Postby twash@slu.edu » Fri Mar 06, 2020 12:33 pm
I attached the program that I just ran today, it took about 30 minutes to run.
MSCI Developed Permormance.WF1
(8.33 MiB) Downloaded 880 times
Postby EViews Gareth » Fri Mar 06, 2020 12:38 pm
That's a workfile. Was there a .prg too?
twash@slu.edu
Postby twash@slu.edu » Fri Mar 06, 2020 12:43 pm
Sorry wrong file
msci developed markets.prg
(151.52 KiB) Downloaded 881 times
Postby EViews Gareth » Fri Mar 06, 2020 2:20 pm
Running the program on your existing workfile (replacing all the fetches with just pageselects), and the program runs in half a second.
Thus the most likely cause in any change would be due to an increase in fetch times.
Before diagnosing further, could you confirm the build date of your copy of 11? (Help->About EViews)
twash@slu.edu
Postby twash@slu.edu » Mon Mar 09, 2020 5:58 am
The build date is October 17th 2019
twash@slu.edu
Postby twash@slu.edu » Mon Mar 09, 2020 6:28 am
Also saving files takes a long time as well.
Postby EViews Gareth » Mon Mar 09, 2020 6:49 am
Can you update to the most recent version and see if the problem persists?
Postby EViews Steve » Tue Mar 10, 2020 6:10 am
Here's a post I wrote about Troubleshooting EViews Slowness. Please take a look at that and let us know if anything seems to work.
