Update leading to higher run times?
twash@slu.edu
The update from eviews 10 to eviews 11, led to a drastic increase in the run time of my programs. A program that would run in five minutes can sometimes take hours. The slowdown appears to be due to it taking longer to generate equations. Does anyone else have this problem?
EViews Matt
Re: Update leading to higher run times?
Would you be able to post one of the programs that is running slowly in EViews 11?
twash@slu.edu
I attached the program that I just ran today, it took about 30 minutes to run.
- MSCI Developed Permormance.WF1
- (8.33 MiB) Downloaded 879 times
That's a workfile. Was there a .prg too?
twash@slu.edu
Sorry wrong file
- msci developed markets.prg
- (151.52 KiB) Downloaded 878 times
Running the program on your existing workfile (replacing all the fetches with just pageselects), and the program runs in half a second.
Thus the most likely cause in any change would be due to an increase in fetch times.
Before diagnosing further, could you confirm the build date of your copy of 11? (Help->About EViews)
twash@slu.edu
The build date is October 17th 2019
twash@slu.edu
Also saving files takes a long time as well.
Can you update to the most recent version and see if the problem persists?
Here's a post I wrote about Troubleshooting EViews Slowness. Please take a look at that and let us know if anything seems to work.
