Kilian add-in
dakila
Kilian add-in
Postby dakila » Tue May 28, 2019 3:21 pm
This thread is about the kilian add-in that that implements the Kilian bias-adjusted bootstrap for VAR impulse response.
heer0
Re: Kilian add-in
Postby heer0 » Thu Aug 08, 2019 3:44 am
Hi guys,
I have applied the Kilian add-in to a standard monetary VAR to retrieve impulse responses with bootstrapped confidence intervals. For a minority of impulse responses, the mean response exceeds the bootstrapped confidence intervals. To me, this does not make sense. For illustrative purposes, I will attach a picture of an impulse response to a monetary shock that exhibits said pattern.
I would be most grateful to you if you could provide me with possible explanations for this response behavior.
Wiz_Ven
Re: Kilian add-in
Postby Wiz_Ven » Tue Sep 10, 2019 12:39 am
Dear guys,
I have a problem with the Kilian add-in. I am running the code (the impulse variable is "dl_t_size") after a VAR estimation and it appears this error "Error 52 in encrypted program". My Eviews version is 11 updated to the last patch. Attached is the Eviews file. Thank you in advance.
ex_kilian.wf1
(18.94 KiB) Downloaded 1962 times
dakila
Re: Kilian add-in
Postby dakila » Wed Sep 11, 2019 12:04 am
The bug is fixed. I hope the moderator will upload the add-in soon.
Re: Kilian add-in
Postby EViews Gareth » Wed Sep 11, 2019 1:59 am
Will be a week or so
SilvioBerlusconi
Re: Kilian add-in
Postby SilvioBerlusconi » Sun Mar 01, 2020 2:58 am
Dear all,
thank you very much for providing this add-in. It is very useful.
I am wondering how can I obtain accumulated 'bands' when I use variables at the first-differences. The Kilian add-in (differently from the 'scale IRFs' add-in') cannot provided accumulated IRFs. I am wondering if it is sufficient to accumulate the bands provided by the Kilian add-in. are you going to implement this tool by allowing the add-in to accumulated directly IRFs and Bands?
Best,
S
dakila
Re: Kilian add-in
Postby dakila » Sun Mar 01, 2020 6:09 pm
I will try to include the option which provides the accumulative IRFs. Yes, you can do this manually after saving the IRFs or write code.
SilvioBerlusconi
Re: Kilian add-in
Postby SilvioBerlusconi » Mon Mar 09, 2020 2:22 am
Thank you vary much for your help and effort.
I do not know neither the code for estimating the Kilian bootstrap in VAR models nor for estimating a 'scale factor for IRF'. The latter for instance is present in the Scale IRF add-in and not in the Kilian add-in.
Best,
S
chris992
Re: Kilian add-in
Postby chris992 » Sat Mar 27, 2021 5:29 am
Hello Dakila,
I have recently downloaded the Kilian add-in and it works fine. The issue is that it only works on var objects. I am running a standard FAVAR monetary policy model following a Bank of England study (2015) code. At the last line, I end up with a matrix storing the impulse responses. I can see the graphs, but I cannot apply Kilian add-in to get bootstrapped standard errors. Is there any way we can modify the add-in or any code to obtain bootstrapped standard errors from matrices or vectors?
Thank you,
Chris
var favar.ls 1 2 pc1n pc2n pc3n pc4n pc5n pc6n pc7n pc8n pc9n pc10n CU_END_MONTH_OFFICIAL_BA
favar.impulse(12,g,matbys=irf) pc1n pc2n pc3n pc4n pc5n pc6n pc7n pc8n pc9n pc10n CU_END_MONTH_OFFICIAL_BA @ CU_END_MONTH_OFFICIAL_BA
matrix (158,11) weights 'creates matrix that will hold the proper weights
group pcn pc1n pc2n pc3n pc4n pc5n pc6n pc7n pc8n pc9n pc10n
matrix xx=@convert(pcn) 'new matrix containing the factors
scalar j
for j=1 to 105 'loop over the 105 slow-moving variables
'Left-hand side of the regression
matrix yy=@subextract(data,1,j,@rows(data),j) 'this sets up the j-th column of data for estimation
matrix btemp=@inverse(@transpose(xx)*xx)*(@transpose(xx)*yy)
weights (j,1)=btemp(1,1)
weights (j,2)=btemp(2,1)
weights (j,3)=btemp(3,1)
weights (j,4)=btemp(4,1)
weights (j,5)=btemp(5,1)
weights (j,6)=btemp(6,1)
weights (j,7)=btemp(7,1)
weights (j,8)=btemp(8,1)
weights (j,9)=btemp(9,1)
weights (j,10)=btemp(10,1) 'the previous linessave the weights
group pcn1 pc1n pc2n pc3n pc4n pc5n pc6n pc7n pc8n pc9n pc10n CU_END_MONTH_OFFICIAL_BA
matrix xx1=@convert(pcn1) 'matrix with factors and CU_END_MONTH_OFFICIAL_BA
for j=106 to 158 'loop over the 53 fast-moving variables
yy=@subextract(data,1,j,@rows(data),j) 'j-th column of data matrix
btemp=@inverse(@transpose(xx1)*xx1)*(@transpose(xx1)*yy)
weights (j,11)=btemp(11,1) 'note coefficients relating cu_int_rate and the data
'Impulse Responses
matrix irf1=@subextract (irf,1,111,12,121) 'irf of pc1n pc2n pc3n pc4n pc5n pc6n pc7n pc8n pc9n pc10n to CU_END_MONTH_OFFICIAL_BA shock
matrix irfmat=irf1*@transpose(weights)
P.S. I accidentally posted this to another thread Eqbootstrap (bootstrap standard errors). I am sorry about that!
chris992
Re: Kilian add-in
Postby chris992 » Fri Apr 02, 2021 2:56 am
On the same note, I have downloaded Eviews 12 and I was trying to run a VAR with user specified Decomposition method and apply Kilian's standard errors, but it says there is Internal error 500. I guess I can't apply both, is there a way to fix that or bypass that?
Thank you,
Chris
Return to “Add-in Support”
