dupplicate view of group makes EVIEWS crash (at list with large datasets)
mamo
Postby mamo » Fri Nov 22, 2019 2:04 am
Dear Eviewers,
using Eviews 11, 17 Sept 2019 build, it seems that working with the duplicate view of a group lets EVEIWS crash, at least when working with a large data set.
See large data file "na.wf1", attached, and try "gr.dups", expand to "Duplicates/Count" and try to click one of the lines.
A scree-shot from EVEIWS crash is attached as "crash.jpg"
Best, mamo
na.wf1
(14.65 MiB) Downloaded 888 times
Re: dupplicate view of group makes EVIEWS crash (at list with large datasets)
Postby EViews Gareth » Fri Nov 22, 2019 8:20 am
No crash for me (although I'm using a more up to date version than you).
Are you using 32bit or 64bit?
mamo
Postby mamo » Fri Nov 22, 2019 8:58 am
I am using 64 bit
The crash comes when trying to click on of the items in the left-hand panel of the open duplicate menu, such as for instance, a line below "Duplicates/ count", or any item above that. Perhaps you may try to select items in order to replicate the crash.
Best, mamo
Postby EViews Gareth » Fri Nov 22, 2019 9:44 am
Yep, see it now, thanks. We'll fix.
