Graphing panel data: one cannot render dual axes overlapping manually at once for each cross-sectional sub-chart
mamo
Postby mamo » Thu Nov 14, 2019 2:06 am
Dear EVIEWers
I use Eviews 11, Sept 2019 build
in a panel chart which has individual charts for each cross-section, it is not possible to make two vertical axes (left and right) overlapping manually, for all cross-sectional sub-charts at once, by using the menu "Options for all graphs" of the graph objects menus.
New Picture.jpg (57.16 KiB) Viewed 10062 times
Rather, one has to change the overlapping of axes for each sub-chart individually via "options for the selected".
This is cumbersome when the combined chart contains many sub-charts from a panel structure.
I found that it is possible to render axes of combined graphs showing individual panel graphs as overlapping in a program (see example program below).
This bug does not happen when graphing data which do not have a panel structure, or when panel data are shown in a stacked or a combined graph.
Best,
mamo
wfcreate a 2000 2010 4 ' create panel data series x=nrnd+4 series y=nrnd+5 series z=nrnd+40 group gr x y z if @isobject("_$gra") then delete _$gra endif freeze(mode=overwrite, _$gra) gr.line(panel=i) ' the bug does not happen when the ' freeze(mode=overwrite, _$gra) gr.line(panel=stack ) _$gra.setelem(3) axis(r) ' switching on the overlapping of axis works in program code ' _$gra.axis(r) overlap show _$gra ' with panel data, it is not possible to switch on ' overlapping of the right axis manually!
