I would like to generate a series of the following formula:
v = 0.606 * v(-1) + e
e is simply the residual of a previous regression, which I can obtain from resid, but the problem with this formula is that it contains a lag of itself - the v(-1) term. Is there any programming code that can take care of this problem?
Thank you very much for your help.
- Eric
Generating a New Variable that Includes a Lag of Itself
Re: Generating a New Variable that Includes a Lag of Itself
Well, you'll have to decide how you want to handle the problem mathematically before you can decide how to handle it programmatically.
What do you want the first value of v to be equal to?
The first value of v is equal to the first value of e
series v=e
smpl @first+1 @last
v=0.606*v(-1)+e
smpl @all
Thank you so much Gareth. I will try this soon and I expect it to work.
I had assumed that I needed a genr command. I am not familiar with the series command.
Also, would the code still work if I replaced the 0.606 with a coefficient from the last regression - c(3) or c(2) for example?
SERIES and GENR are interchangeable - they're the same command. It's a matter of personal preference that I use SERIES, but a lot of the others around here use GENR.
And yes, it would work if you replace 0.606 with c(1)
I just tested the code that you gave me and it just produced a vector of NA's. I think it may be due to the fact that the samples might be off. Here is the code that I used:
The first value of ehat is actually the fourth value in the total data set. Is there a way to correct for this in the code?
smpl 1 42
genr lninvpc=log(invpc)
ls lninvpc c t
genr lninvpc_detrend=lninvpc-(c(1)+c(2)*t)
ls lninvpc_detrend c gprice lninvpc(-1) gprice(-1)
smpl 4 42
ls lninvpc_detrend c gprice lninvpc_detrend(-1) gprice(-1)
genr ehat=resid
genr vhat=ehat
smpl @first+1 @last
vhat=c(3)*vhat(-1)+ehat
smpl @all
change
to be
smpl @first+1 @last
smpl 5 42
