Generating a New Variable that Includes a Lag of Itself
einsler
Postby einsler » Fri Feb 19, 2010 1:41 pm
I would like to generate a series of the following formula:
v = 0.606 * v(-1) + e
e is simply the residual of a previous regression, which I can obtain from resid, but the problem with this formula is that it contains a lag of itself - the v(-1) term. Is there any programming code that can take care of this problem?
Thank you very much for your help.
- Eric
Re: Generating a New Variable that Includes a Lag of Itself
Postby EViews Gareth » Fri Feb 19, 2010 2:05 pm
Well, you'll have to decide how you want to handle the problem mathematically before you can decide how to handle it programmatically.
What do you want the first value of v to be equal to?
einsler
Postby einsler » Fri Feb 19, 2010 2:15 pm
The first value of v is equal to the first value of e
Postby EViews Gareth » Fri Feb 19, 2010 2:18 pm
series v=e smpl @first+1 @last v=0.606*v(-1)+e smpl @all
einsler
Postby einsler » Fri Feb 19, 2010 2:34 pm
Thank you so much Gareth. I will try this soon and I expect it to work.
I had assumed that I needed a genr command. I am not familiar with the series command.
Also, would the code still work if I replaced the 0.606 with a coefficient from the last regression - c(3) or c(2) for example?
Postby EViews Gareth » Fri Feb 19, 2010 3:00 pm
SERIES and GENR are interchangeable - they're the same command. It's a matter of personal preference that I use SERIES, but a lot of the others around here use GENR.
And yes, it would work if you replace 0.606 with c(1)
einsler
Postby einsler » Tue Feb 23, 2010 9:13 am
I just tested the code that you gave me and it just produced a vector of NA's. I think it may be due to the fact that the samples might be off. Here is the code that I used:
smpl 1 42 genr lninvpc=log(invpc) ls lninvpc c t genr lninvpc_detrend=lninvpc-(c(1)+c(2)*t) ls lninvpc_detrend c gprice lninvpc(-1) gprice(-1) smpl 4 42 ls lninvpc_detrend c gprice lninvpc_detrend(-1) gprice(-1) genr ehat=resid genr vhat=ehat smpl @first+1 @last vhat=c(3)*vhat(-1)+ehat smpl @all
The first value of ehat is actually the fourth value in the total data set. Is there a way to correct for this in the code?
Postby EViews Gareth » Tue Feb 23, 2010 9:18 am
change
smpl @first+1 @last
to be
smpl 5 42
