Extracting Equation from Eviews to Excel
jiangsujie
Eviews 7 has an excel plug-in that allows users to extract data from EViews workfiles. But i've found that the Excel plug-in can extract only series or Vectors, not equations or groups, does anyone know how to use Eviews plug-in in excel to extract them?
Thanks!
sujie
Thanks!
sujie
Re: Extracting Equation from Eviews to Excel
I'm not sure your question really makes much sense. Excel doesn't have an equivalent of an Equation object. How would EViews send it across?
The EViews Excel Add In was meant to be a helpful utility in allowing users to access EViews data directly thru the new OLEDB driver. It is limited to those objects that can be read by the OLEDB driver.
Unfortunately, at this time, the OLEDB driver does not support reading group or equation objects. Support for reading groups may be added in near future.
jiangsujie
What i mean is that if Eviews equation estimations are updated regularly, it's a bit troublesome to copy and paste the parameters into excel manually, so the ability to access Eviews equations from Excel would be very helpful.
For now, do you have a solution for extracting equation parameters for a group of equations?
Thanks again!
Thanks again!
Generally, the parameters are stored in the C vector. Can you send that across?
Startz is right. An Equation object could not be passed from EViews to another package, such as Excel, since Equations are somewhat unique to EViews. However, you can always pass the results of an Equation over to Excel, since you can generally put the results into Vector or Matrix objects, then pass those over.
Hello Gareth! Could you please explain how to put the results from an equation into a Vector or Matrix? Thanks in advance!Startz is right. An Equation object could not be passed from EViews to another package, such as Excel, since Equations are somewhat unique to EViews. However, you can always pass the results of an Equation over to Excel, since you can generally put the results into Vector or Matrix objects, then pass those over.
matrix coefs = eq1.@coefs
matrix cov = eq1.@coefcov
Thanks for your fast reply Gareth!Where eq1 is the name of your equation. The other data members can be found in the equation section of the Object Reference.Code: Select all
matrix coefs = eq1.@coefs matrix cov = eq1.@coefcov
I'm automating a regression evaluation by using Eviews from Visual Basic.Net. I'm able to send data to series, and executing an equation with the following command:
app.Run("LS LOG(MWH) @TREND H1 H2 H3 H4 H5 H6 H7 C ")
Do you know how to retrieve the coefficients returned by the equation, with VBnet?
Thank you very much!
Make a small change to your Run command to actually create an equation object like this:
Then, to retrieve the parts, you don't actually have to create separate vectors/matrices. Just run:
or
app.Run("EQUATION EQ1.LS LOG(MWH) @TREND H1 H2 H3 H4 H5 H6 H7 C")
app.Get("=EQ1.@coefs")
app.Get("=EQ1.@coefcov")Re: Extracting Equation from Eviews to Excel
Thank you very much Steve! I appreciate your help
CharlesLogan
It would be very handy for Eviews to have the ability to export to Excel the Substituted Coefficient representation of an Equation as a STRING.
It is. See the @subst data member of an equation. Put it in a table, and save to disk as a .csv which can be read by Excel.
Or use COM to send the string across to Excel
"It is. See the @subst data member of an equation. Put it in a table, and save to disk as a .csv which can be read by Excel."
Is there anything similar for use with the one or more equations of a VAR object? Or possibly a workaround if such a command does not exist?
