Extracting Equation from Eviews to Excel
jiangsujie
Postby jiangsujie » Thu Feb 11, 2010 5:32 am
Eviews 7 has an excel plug-in that allows users to extract data from EViews workfiles. But i've found that the Excel plug-in can extract only series or Vectors, not equations or groups, does anyone know how to use Eviews plug-in in excel to extract them?
Thanks!
sujie
Re: Extracting Equation from Eviews to Excel
Postby EViews Gareth » Thu Feb 11, 2010 8:56 am
I'm not sure your question really makes much sense. Excel doesn't have an equivalent of an Equation object. How would EViews send it across?
Postby EViews Steve » Thu Feb 11, 2010 10:57 am
The EViews Excel Add In was meant to be a helpful utility in allowing users to access EViews data directly thru the new OLEDB driver. It is limited to those objects that can be read by the OLEDB driver.
Unfortunately, at this time, the OLEDB driver does not support reading group or equation objects. Support for reading groups may be added in near future.
jiangsujie
Postby jiangsujie » Fri Feb 12, 2010 5:53 am
What i mean is that if Eviews equation estimations are updated regularly, it's a bit troublesome to copy and paste the parameters into excel manually, so the ability to access Eviews equations from Excel would be very helpful.
For now, do you have a solution for extracting equation parameters for a group of equations?
Thanks again!
Postby startz » Fri Feb 12, 2010 7:39 am
Generally, the parameters are stored in the C vector. Can you send that across?
Postby EViews Gareth » Fri Feb 12, 2010 9:03 am
Startz is right. An Equation object could not be passed from EViews to another package, such as Excel, since Equations are somewhat unique to EViews. However, you can always pass the results of an Equation over to Excel, since you can generally put the results into Vector or Matrix objects, then pass those over.
amina
Postby amina » Mon May 10, 2010 9:04 pm
Hello Gareth! Could you please explain how to put the results from an equation into a Vector or Matrix? Thanks in advance!
Postby EViews Gareth » Mon May 10, 2010 9:31 pm
matrix coefs = eq1.@coefs matrix cov = eq1.@coefcov
Where eq1 is the name of your equation. The other data members can be found in the equation section of the Object Reference.
amina
Postby amina » Tue May 11, 2010 4:38 am
Thanks for your fast reply Gareth!
I'm automating a regression evaluation by using Eviews from Visual Basic.Net. I'm able to send data to series, and executing an equation with the following command:
app.Run("LS LOG(MWH) @TREND H1 H2 H3 H4 H5 H6 H7 C ")
Do you know how to retrieve the coefficients returned by the equation, with VBnet?
Thank you very much!
Postby EViews Steve » Tue May 11, 2010 8:07 am
Make a small change to your Run command to actually create an equation object like this:
app.Run("EQUATION EQ1.LS LOG(MWH) @TREND H1 H2 H3 H4 H5 H6 H7 C")
Then, to retrieve the parts, you don't actually have to create separate vectors/matrices. Just run:
app.Get("=EQ1.@coefs")
or
app.Get("=EQ1.@coefcov")
amina
Postby amina » Tue May 11, 2010 8:10 am
Thank you very much Steve! I appreciate your help
CharlesLogan
Postby CharlesLogan » Fri Dec 17, 2010 3:46 pm
It would be very handy for Eviews to have the ability to export to Excel the Substituted Coefficient representation of an Equation as a STRING.
Postby EViews Glenn » Fri Dec 17, 2010 4:24 pm
It is. See the @subst data member of an equation. Put it in a table, and save to disk as a .csv which can be read by Excel.
Postby EViews Gareth » Fri Dec 17, 2010 4:39 pm
Or use COM to send the string across to Excel
vkarora
Postby vkarora » Fri May 31, 2013 11:02 am
"It is. See the @subst data member of an equation. Put it in a table, and save to disk as a .csv which can be read by Excel."
Is there anything similar for use with the one or more equations of a VAR object? Or possibly a workaround if such a command does not exist?
