Copy values from cross-section to entire vector
stefanp
Postby stefanp » Fri Jun 01, 2018 3:55 am
I use a panel data set. I need to copy some value from cross-section AA to another cross-section AB, but not to any other cross-sections.
So far, I create an auxiliary series TEMP, copy the value from AA to TEMP. However, when I want to copy TEMP to AB it does not work as for the corresponding sample (AB), the series TEMP contains only NAs.
Re: Copy values from cross-section to entire vector
Postby EViews Glenn » Fri Jun 01, 2018 4:24 pm
Can you be a bit more specific about what you are doing? What values in AA need to be copied? Is it the value for one date, or values for a range of dates? Are we matching up observations by-date?
stefanp
Postby stefanp » Mon Jun 04, 2018 2:26 am
I have created a workfile and a codefile which does the required task. However, I assume this approach is way too complicated for what I require.
example.wf1
(12.29 KiB) Downloaded 404 times
example.prg
(275 Bytes) Downloaded 415 times
Postby EViews Glenn » Mon Jun 04, 2018 6:27 pm
series var2a = @meansby(var2, country, date)
